Thread: Special request
sikeston34m
sikeston34m's Avatar
03.28.2009, 11:04 AM
Can somebody make me a balancer Y adaptor to balance and charge two batteries at the same time using one balancer unit. I'll be charging/balancing a 3s and 2s 25C 5k Neuenergy lipo packs on a Hyperion charger(0610iNet).
Please pm me if you can do it and how much you're going to charge me for parts and labor. I don't have much free time now since reporting onboard the USS George Washington. Thank you very much. I'm stationed at the US Navy base here in Japan.
I believe the "not used" wire does have to be used. Otherwise the balancer is only going to see 4 cells.
This wire should splice into the far right hand wire of the 3S pack.
Double check me, but I believe the balancer will see no voltage for the 4th cell with the "not used" wire unless you change it.
