Originally Posted by MetalMan
You could use it in your CRT if you convert over to the CR buggy mount and center bulkhead, otherwise you might not get the pinion to mesh with the spur. In fact, I am using the CR buggy center diff unit on my CRT.
So I must buy d cr center diff mount. Any other mod I need to do? So the slipper diff comes with 46 or 50t?
