MetalMan
MetalMan's Avatar
03.29.2009, 01:41 AM
You can use the Slipperential in the CRT, but you will need to buy the Jammin' X1-CR motor plate, and X1-CR center bulkhead. Then you will need to make sure you can gear your motor properly with whichever spur gear you choose (I would recommend you use the 50t).
