superek4
superek4's Avatar
03.30.2009, 09:39 AM
Changing the front/rear ring and pinion gears isn't an absolute necessity - as long as you have matched your motor, battery, gearing, etc. to the gears you have, you will be fine.
Even though it isn't NECESSARY, I think it is a good idea to use the truggy ratio diffs(if it was my truck, I would use the truggy diffs). The spiral gears are stronger, quieter and smoother, for one. For another, they allow a much smaller spur while retaining a larger pinion, which will be smoother again as well as last longer.
U mean x1 CRT is not using truggy diff for front n rear isn't it 43/13? Or u meant 45/10 is better?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
