Originally Posted by brian2njoy
thanks for your help glad to see someone from la i have put 120k lock fluid in,i put the center diff in and i still need to lock in 2nd gear i thought the center diff changed all that but i still need to lock in 2nd gear because i want to get rid of the mechancal brakes and servo
Are you in LA? There are a few of us in the NOLA area...
Ditching the servo and mech brakes is a good idea. Did you find BrianG's info on locking the revo in 2nd? I think it is in the revo section, as a sticky.
The traxxas center diff just replaces the output shaft, you will still need to mod the 2nd gear spur to lock it up. Pretty easy to do, just filing some slots on the gear to put screws in.
