ambryatim
03.30.2009, 04:40 PM
If it doesn't really matter to you, get the 80mm. The extra length will just keep it cooler. And if it's too powerful, you can always turn down the power. Better to have it and not need it, than to need it and not have it.
Do you think that the 2000kv would be sufficent on 3-4S???? Because that is all I can find in the 80mm no one seems to have the 2200kv and I called Medusa and they said that it could be 2 or more weeks I guess I could always wait, but man going 2 or even 3 weeks with out running that would be tough......I know I could always gear up on the lower kv but then I might run into some heat issues, right???
