Originally Posted by BrianG
I figured they would be in parallel at 3s. The middle paragrah in my last post compared the runtime for a 3s parallel config and a 6s series config. Same batteries, different hookup. And yeah, the ohms law still applies.
1600kv on 6s would be 35000 rpm, right in the sweet spot. And as long as you're looking for 40-45mph speeds, it would be perfect IMO. You could go with the 2000kv too, just gear down, but 2000kv on 6s would be almost 45k rpm, which is higher than most people like to run.
Which would equate to more (higher) temps. Hmmm well I am courious as to why the Castle Neu is 2200kv and most people will run 4S (32000rpm), it seems to me that castle would offer it in a lower kv so we all could take advantage of the 6S rating on the speed control.
