Thread: Lipo Puffed?
03.30.2009, 08:20 PM
Reset the lvc to the correct setting manually. I like 16v for a 5s setup. As long as the pack does get hard after it cools off you should be fine. You may notice that it is more out of balance after a run than it was before. Just make sure it is completely balanced, as that may take longer than the charge...
