DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
03.31.2009, 01:13 AM
OK, I see the cvd's on flm's website, but where are the adapters you mentioned?
sorry it took so long to get back to you...i must have gotten side tracked with something before i answered and then forgot to respond.
you can either use the slash or the extended/rusty adapters....if you're uising the E-maxx sized tire/wheels, I would use the extended adapters
http://www.rcbros.com/cart/Scripts/p...?idproduct=273
http://www.rcbros.com/cart/Scripts/p...?idproduct=278
you need to lock the diff because well, in my case with the amount of voltage i was putting out, it would turn to liquid even with putty. it needs to be glued or locked with a spool.
FYI...if you get the flm cvds, you must run the wide rear a-arms too.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
