speedemall
03.31.2009, 10:35 AM
FYI if that this the castle motor it is only rated to 4S - I personally ran mine for a few times on 5s before they updated the spec and it was ok.
Just be advised that you are running out of spec and hence warranty...
You are just missing one bit of info - desired top speed...
so the limit is 4s regardless if it is v3? I would like to get a top speed between 45-60 mph nothing to hairy.My slash is clocking 53 on a 9000kv 2s pack and I'm comfortable with that just not in the dirt
