Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.31.2009, 03:40 PM
Originally Posted by eovnu87435ds View Post
i Didn't think so... what about resistance? would it cause alot of resistance compared to soldered on normally?
You will have no problem with resistance, Tekin RX8 has solder tabs that you can mount the wire to at any angle of your choice. Just drill out the bullets (I would drill out where the solder hole is already) to accept the motor wire and fill the inside with solder.......perfect connection
You can purchase right angled heat shrink if you want that perfect looking connection, we use them at work........here's a link to a site I found quickly online.......
http://www.peigenesis.com/pdfs/amphe...SG_184-185.pdf
I like it.......I LIKE IT ALOT!!!!!!
