03.31.2009, 04:17 PM
Hey Brian, found something you need to fix
Anyways, it is the LST 1st gear (low range). You have the primary reduction listed as 70/18, that is actually the 1st gear ratio of the 2speed on the outside of the tranny.
The correct ratio is 30/15, coupled with the bevel output ratio of 30/15 you get 4 to 1 reduction when the tranny is in low range.
Just figured that I would point that out... Thanks for the great tool again, I use it daily! (that sounded questionable)
Any chance you could add mod 1.5 to the gear diameter calculator. It would be handy with figuring stuff out for the baja 5b and 5t.
