Well, using
this, I get 31.6mm between the shafts with Mod0.8 19/56. But to suggest a replacement for any other pitch, you'd also need what spur (or pinion) you plan to use so you can solve for the unknown. But, just to throw a number out there, let's say you want to use a 90T 48P spur, that would be a 25T pinion to keep the same shaft to shaft distance.
