Anyone using Mike's v3 Revo diff kit? I have a few questions
Anyone using Mike's v3 Revo diff kit? I have a few questions - 03.31.2009, 08:41 PM
It seems that once I tighten the case screws down tight, it binds the gears...I have shimmed, taken out the shim, etc...always the same prob...If I back off of the case screws 1/2 turn all is well...wierd
Also, I am confused as to what the large washer, (compression washer?)not sure as to what to call it does. There is also a black washer as well w/the kit... a little thicker than the shim, does that go between the bearings? Maybe I am missing something?
