Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
04.01.2009, 09:51 AM
Originally Posted by Sammus View Post
Not really guarantee. I was having blackout problems using a CCBEC and after lengthy email discussion with CC tech supp, nothing was different (tried ferrite rings and rerouting wires basically). I ended up adding over 10,000uF capacitance and it didn't seem to make any difference to my Rx (futaba 3pm) blackouts. Still on stabbing the throttle totally unloaded the voltage would drop enough to reset the Rx. Thing I don't get is that the problem went away using the onboard BEC. It got hot, but had no blackouts. *shrugs*.
There are several types of caps out there. What was the make/model you purchased/used? What was the application as well? And if you swapped out the receiver for a different one, did it still do it?
Joe Ford
Product Specialist
