RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.01.2009, 08:13 PM
It will work fine in the SC8 - the GTP uses a funky 19mm bearing, so finding an 8x19mm bearing will be the challange. I think using an 8x16 bearing with a 3mm press-in delrin ring (bearing spacer basically) would be the easiest plan of action for the GTP. The GTP will likely ned some shimming as well, nbut this could be done in one shot by building the shim into the bearing spacer. :)
