Sammus
Sammus's Avatar
04.03.2009, 05:48 PM
neu cells are about a billion times better than maxamps, and probably nearly twice as good as zippy, so you should be right to go :p
but in all seriousness, wtf? a couple of idiots trying to set the land speed record on cheap dodgy batteries break there car and suddenly theres 17 pages of fear that you cant run the mmm with anything less than the aboslute pinnacle of battery tech. geez chill out guys, I often run 2300mah A123 cells in 7s and haven't had a problem with it. ANY 4000mah 6s lipos are going to be better suited than that. just dont do anything stupid. and emaxxnitro: that means if you really do want the worlds second fastest erevo, yes you will need good cells.
and btw, what is a mamba monster pro?
