04.03.2009, 08:20 PM
Jb weld and an overnight dry... You should have enough threads left to get it to start and hold while it dries.
Will that hold the weight? That's a lot of motor hanging out there.
Drill out and tap for M4 - Then use one of mikes end bell covers :) to get you 4 spangly new m3 holes
Not the screws in the endbell, the endbell in the can is stripped. So the threads of the endbell itself and the corresponding threads in the motor can are stripped. (Its a screwed on endbell)
a kb45 sized rcm heatsink/clamp would work
