04.04.2009, 01:41 PM
Max motor rpms will be around 30k, nothing wrong with that. I doubt a big block nitro motor can push out much more rpm.
As long as you can gear it for 40 I see no reason it will not perform well. Voltage drop will not be much due to the lower kv motor and 6s lipo. I have been experimenting with lower kv motors and think they are the way to go. 4 pole motors like neus have plenty of torque, and the higher gearing needed to get the speed out of them does not seem to bother the motors at all. You may want to run 50+% punch control, but other than that I think you have a good setup.
I think you can expect around 30-35min of runtime with mixed bashing, and maybe 20-25min of hard track use.
