04.05.2009, 12:17 PM
Originally Posted by NoControl View Post
Linc, was just wondering you using the 610i or the 610i duo? I have the duo and its sweet atm for NiMH's. Also I think if you're gonna go for anything higher then 6s the duo may be an option for you or anyone, since as I'm reading the box it says and I quote, "*EOS610iDUO in SYNC Mode can charge two seperate, similar Lithium packs as a series-wired "flight pack" of up to 12s total! Or use solo Mode to charge two different packs on the seperate ports at the same time." That and once you setup the pack info on the memory it usually predetermines you charge rating, and if your ps doesnt have enough power the charge will adjust its power intake to limit the power used from your ps.
Just my 2cents about hyperion, definetly a good charger!
Hey, I actually have 2 of the 610i chargers, so I can link them to charge a larger than 6s pack.
Plus I have a 1210i too, and a pair of lba10 balancers that I can link to do the same thing. I do not plan to go over 6s packs, but will be using the chargers linked to charge and balance my 10s baja 5b packs (a 6s and 4s with the same spec cells).
I really like the hyperion chargers with built in balancers, work much better than a stand alone or charge thru setup.
