jsr
04.05.2009, 01:31 PM
I've run my EZRuns from 3.75 - 15* timing and from Level 3 to 7 punch without problems. But I didn't go to the extremes. That's a bit scary.
It sounds like the punch settings might be reversed from what it says in the manual. Per the manual, the higher the stting, the more punch (less punch control). But it seems that the lower the setting, the more current it draws which means more punch...contrary to what the manual says. This is the way MMs and MMMs work so it wouldn't be a complete surprise if it does actually work the same as CC ESCs but just written wrong in the literature.
