MetalMan
MetalMan's Avatar
04.05.2009, 02:34 PM
8s with a medusa 80mm 1100kv gets my vote.
The exact setup my Savage has been running
That's gonna be one HEAVY truck! Mine Savage 25 with FLM extended low CG chassis and with a center diff weighs a bit under 12.5lbs.
Might you consider a center diff conversion similar to other center diff Savages out there (like mine)? Could save you over half a pound and improve performance, as well as eliminate that weak spur/pinion link the stock truck uses.
