Finnster
KillaHurtz
Finnster's Avatar
04.05.2009, 06:03 PM
Originally Posted by MetalMan View Post
The exact setup my Savage has been running
That's gonna be one HEAVY truck! Mine Savage 25 with FLM extended low CG chassis and with a center diff weighs a bit under 12.5lbs.
Might you consider a center diff conversion similar to other center diff Savages out there (like mine)? Could save you over half a pound and improve performance, as well as eliminate that weak spur/pinion link the stock truck uses.
Heavy is ok as I want a big bruiser of a truck, and I'm not the jumping buildings type. Nor looking to set landspeed records.
But yes, I really really want a CD. I had been working on a mount end of last year, but its a pain and expensive to do. Got halfway thru it. I wanted it to mount in at least one set of tranny holes and have motor forward. Later decided just to mount on a skid plate like a traditional diff.
Lately I saw the (G?) maxx CD mount that mike made. I would really like something like that w. his slipdiff. I've got time to put this together, so I'll wait on those. the tekno mount is a simple mount for now and to see how it performs. If need be I'll step upto the 80mm 1100kv if needed.
What is the amp draw on that thing btw?
