bdebde
That's All Folks!
bdebde's Avatar
04.06.2009, 09:47 PM
Originally Posted by bruce750i View Post
Hey Dubs Chops,
Lets not assume you have a problem until you actually measure the motor temperature. Although 180-200* would be bad thing.
Correct: The wire polarity only effects rotation direction.
Originally Posted by skellyo View Post
I agree. Put a temp gun on it. It may not be nearly as hot as you think.
90-100*F is hot to the touch still, you really need an IR temp gun with BL motors and escs to get accurate readings. They only cost like $5-10 or so.
If you are guessing at the temp... STOP, and get a temp gun... period. It is not worth destroying something (expensive motor).
