Foxracin
04.06.2009, 09:56 PM
Got everything and put it together and ram 2 packs through it. One word nasssssty. I love it. Now I jsut need a good servo and Ill be set for some racing. I extended the switch wires and put the switch in the stock location. Looks clean. Got a question though. Im using the Losi motor mount and when the motor is mounted the wires coming out of the motor are pointing straight up and you have to mash the body down on the to get it on. If you rotate the motor to the other set of holes then they hit the driveshaft. Is there anyway to loosen the 3 screws and rotate the end plate to change the position of the wires? I need to get a 8e body for more clearance. It may be fine with it.
Yea it already dirty. lol
