Originally Posted by lincpimp
Sounds like you have it set correctly.
Are you using the built in balancer while charging? I just ask as you need the correct adapter board to charge a fp lipo as it has a thunderpower style balancing tap.
18.5v is the nominal voltage. 21v is the total voltage that it should charge up to on the charger.
yes i have a flight power balancer adapter thingy and i was using it and i will let it charge up to 21v. i love this charger by the way!!!!
