04.07.2009, 04:51 PM
IMO..For $30- more, get a mmm esc...even if you have to save a bit more. It will give you more battery choices later.
Don't skip on your esc or motor
If you skimp, you will end up buying components twice....I made this mistake and ended up spending much more in the end that I should have. Save a bit more if you have to and buy better components. Well worth the extra money in the end....(less down time and more play time)
I am also doing a 3.3 revo conversion and I will be using the new Tekin RX8 system when it comes out or a mmm esc w/a Neu 1515.
