rchippie
rchippie's Avatar
04.07.2009, 07:02 PM
Balls they call it metric 48p but it is 0.6
I believe that this what I need Metric .6 Module Steel Alloy Pinions
1112 Metric Steel Alloy 48 Pitch Pinion 12 Teeth $3.50
1113 Metric Steel Alloy 48 Pitch Pinion 13 Teeth $3.50
The aim of the different pinions is to overdrive the front slightly which helps stop the rear pulling the front over...
I guess you got the right ones according to the robinson site . The part #'s you listed are the metric ones .
http://www.robinsonracing.com/catalo...on.html#metric
I went for the MAYHEM wheels because they offer a berg offset . so the truck is not to wide .
REAL MEN RUN BRUSHLESS
