What did you do to your clutch for it to go out after 60k miles
I consider 200k miles good life for a clutch, there better have been some track time involved...
Your stalling problem is most-likely electrical, see if a code scanner can pick up anything wrong once you get it to stall (the computer should store error codes for ~50 starts) and see what it says.
