squeeforever
squeeforever's Avatar
04.07.2009, 11:59 PM
Need to know what weight fluids you have. Like I said though, adding thicker fluid in the front might tame down the front diff unloading, but it won't do anything for the wheelies, and you might also need to go higher in the center diff, but that will make wheelies even more of a problem. If you can, get one of the custom made center diffs that a guy use to sell on Ebay (I think it was cowboy??). There a great center diff since there 6 spyder and not 4 like the Traxxas. That will allow you to use thinner fluids since 500k is about as thick as you can get and isn't always thick enough for the Traxxas CD. I'd try and go thicker in the front first though. That won't keep it from unloading while in a straight line, but more so if your going into a turn and the inside front wheel is the one unloading.
