SpeedAssault
SpeedAssault's Avatar
04.08.2009, 10:01 PM
I'd just spend $110 on two of these - Neu 30's 5s2p 5k
http://www.flydma.com/product_info.p...roducts_id=254
Man Talk about Confusing Hate to burst your bubble but You cant do that:
Found here http://www.robotwars.00server.com/tutorials.html
Lipos wired in series (+ to – ) will increase the total voltage. For example, two 2s lipos wired in series will create a 4s lipo. The mah capacity will remain the same.
Lipos wired in parallel (+ to +, - to -) will increase the total mah available, For example, two 2s 5000mah lipos in parallel will create a 2s 10,000mah lipo. The voltage remains the same.
Please explain how you series these batteries to get 5000mah but only get 5s ?
Per voltage and MAH the price is not comparable
Hear me out , a 3200 battery at 5s is cheaper to do twice than to build one at only 5000 mah ??
Is there a battery expert in the house ?
I 'll search in tutorials again
Sure dont make getting a battery easy do they
