SpeedAssault
SpeedAssault's Avatar
04.08.2009, 10:54 PM
Yep double the capacity (mah) and you double the amp output. The C rating remains the same as that is related to the individual cells.
Wow man thank god you are here, seriously, thank you for explaining this. let's rap this up
So it's a great package to run and it will produce how much continuous amps ? 160 amp or 125 ? or 128 20c + 64amp x 2 =128 .. which is plenty for a 2200-2383 KV to provide speeds above 55mph on a less than 10lb car ? ?
