Thread: lipo low cell
04.10.2009, 09:38 AM
I would fully charge it and run it a few time, and keep a record of how out the balance is after you run it. You may have a weak cell, but if it does not puff when you run it you should be fine. As long as you balance it every time you charge and do not let that cell's voltage get too low when you run it you will get more use out of it.
