Always Dreamin
04.10.2009, 11:30 AM
Originally Posted by E-sav View Post
The slash is better than the Rustler for the same reason an extended FLM Rustler is better than a normal rustler. It's about an inch longer, which means more stability. A high speed slash requires either modding or removing the body, fitting different wheels and tires and fitting shorter shocks. That's all.
The Rustler is a bit shorter, but regardless, bring a VXL Slash and a VXL Rustler and we'll see who wins. And if you did those upgrades to a Rustler (new tires) and lowered it, then the Slash wouldn't have a chance. The higher CG of it just does not allow it to keep up with the Rustler. And running without the body is only asking for messed up ESC or body posts, or whatever else gets in the way. In all fairness, when Traxxas built the Slash they were going for scale, not performance.
