Small Update:
Raze ST Truggy
Small Update: - 04.10.2009, 07:10 PM
I just swapped out the 36-60-2000 medusa for a 36-80-1600 Medusa in the buggy. The 60mm had a 12t pinion on it and a put a 20t on the 80mm. I wanted to see if I could make the motor sweat, after two seperate ~10min bash sessions of mostly speed runs the hottest I could get the motor was 120f. The MMM V1 is still going strong, and the 4000mAh 6S 20C Zippy didn't break 90f.
I'm going to go throught the diffs and add silicon lube and then I think that I'm going to sell the buggy with the 60mm and put the 80mm in the truggy.
-Brian
