Thread: Neu 2700 on 6s
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
04.11.2009, 05:58 PM
If you want fast. Its better just to run a 2200 kv on 6s and the castle 2200 motor is actually advertised to be able to do so. Gear up a little and it will be about the same as your 2650 on 6s. The only difference between the two motors is the change in length, which cause the kv to be lower.
Area 52 Ranch Raceway
T.R.C.R.
