Delta Maxx
04.13.2009, 11:55 AM
now it's real fun, no compromise if i want, i give full throttle and the car move forward without any wheely. i could drive up the hill and give full throttle, the only result is that the car go faster up the hill.
befor with the short Chassis on the same hill the car always make wheelys or flip over.
but the heat ? outside we have 23 degree today
i run 17 min on a real dusty and loose gravel gound with some gripy areas than stoped
the 9920 was about 40-55 degree
the 20XL-12 was about 80-90 degree (i need a temp gauge)
on 6s2p 4000mAh
the gearing is 17/40 in 1st gear
2nd gear is definitive to hard for the esc and the motor with this gearing
i think the whole setup is a winter halfyear setup as well if i go 14/40 in 2nd gear
any proposals ?
and do anyone know a body that will fit on a 425mm whellbase my mamouth body is a bit to short
some pic after testdrive
