04.16.2009, 10:20 AM
Originally Posted by Unsullied_Spy View Post
I was wondering about the rear of the motor being supported because that's a lot of weight hanging off those 2 little screws. I'm sure the mount itself is strong, but I don't want to break off screws inside my motor coming down from a hard landing. This would be more of a problem for me because I plan to use a 1527 (longer) but I wouldn't want a motor as heavy as the 2215 supported by 2 little screws unless they were at least a grade 12.
If you plan to use a 1527 I would go with a clamp style motor mount. I will run a pair of 1521 2y motors in mine, and just need to getthe critical measurements to the laser cutter. My motors will be stacked, so I needed a solid way to mount the motors in the same plane. Pinion selection is the worst part right now, I found some 12t pinions that are way too long, and still have to be drilled and tapped for set screws. The only benefit to the addl length is that I can adjust where the motors sit so that I can clear the front of the tranny case. I will hopefully have more work done on this project next week...
