Originally Posted by Chris Corbett
THanks for that. I assume the custom cut off is an option on the Castle Link? I have the usb and downloaded the software but for some reason it is not reading the esc so I programmed manually.
Do you need power to the esc and switched on to link it?
It did work once but not this time!!
You do not need the power on to get it to work. Just plug it in.
