crazyjr
crazyjr's Avatar
04.16.2009, 08:33 PM
Originally Posted by Edumakated View Post
How long do you need to run for???? I could get 45+ minutes on a 3s 8000 pack in my Rustler VXL geared to the moon.
I am thinking about getting on of these mini-revo's too, but I can't see needing to run more than 30 minutes or so at a time. I would get bored before the pack dumped.
Just looking at what can be done, I have played with 1/10 high volt, now i want a 1/16 high volt setup. I guess the main reason is that with the smaller battery packs, the max C is close to the max continuous of the esc/motor combo. I figure the higher voltage will lower the amp needs and allow the batteries to run better, longer and with less stress
