Thread: Hyper 9E
crazyjr
crazyjr's Avatar
04.16.2009, 08:42 PM
Originally Posted by Marvin View Post
80mm exactly - though there will be no room for motor wires.
There is a 43T crown gear and 11T pinion - so 3.909...
I don't think you would be able to use a smart diff either - it's not the spur gear size that's the problem, it's more that the diffs are so short - the entire centre diff (spur gear to diff case bottom) is only 18-19mm long!
Nice specs, looks like they used a hyper 12 center diff, means there might be a plastic option for the >5 class cars
