04.17.2009, 02:57 PM
You definitely need a larger spur... Or more reduction in the diffs. A motor that spins around 30k rpm is fine if you are geared for 40, but geared for 50 you will have a ton of startup load, and you may have issues...
maybe 2.2 tires
