04.17.2009, 07:32 PM
You can check the polarity by using a multimeter. Stick the multimeter's red probe into the positive terminal of your battery and the black probe into the battery's negative terminal. If the reading you get is a - voltage, then the battery wires are reversed. It should give you a positve voltage readout if the battery is wired correctly.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
