What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.17.2009, 11:31 PM
My desktop should have the same results, right? If not the slow speed is computer related?
If you aren't using a wireless connection, then your speed should be a lot higher. It could just be the settings on your LAN card. You could try setting a static IP, or disabling some IE services/functions. Like you said I doubt it is spyware, but you should scan anyways. An easy way to tell if there are programs hogging bandwidth is to open Task Manager (Ctrl+Alt+Delete) and click on the "Networking" tab. If there is a lot of activity and you aren't DL'ing anything () then your computer might be sick...
