Originally Posted by scarletboa
just convert to brushless the easy way like i am. get a KB l or xl (if you want overkill) and the kershaw motor mount. you will either have to modify the mount yourself or have the owner of kershaw designs make you a custom one like mine. a mystery 200a esc can be had for $50 shipped on fleabay and the motor is about $50. the xl motors supposedly have more power than the CC/NEU motors.
only about $100 for the whole power system and you don't have to get the flux parts. you can use the set screw in the tranny to make the shifting point too high to reach, thus locking it into 1st gear.
Adjusting the 2nd gear shift point will not lock the tranny in 1st, it will just prevent the tranny from shifting. You will still have the OWB and will have to use mech brakes and mech reverse. Plus the flux center shaft is around 10-11 bucks shipped, not going to break the bank with that...
