gabry356
04.20.2009, 10:57 AM
Ok...Let's start saying that this package have been developed to be really budget friendly so what you see here is just an entry level compared to your electronics...
Chassis is a gmstyle drift spec, no central diff, locked rear and slowed front diff, electronics: I've been using anything from 60amp ez esc, 75 amp novatech esc with keda motor or ez 80amp up to ez 150amp with medusa and 6s....just decide at what speed you want to drift...with these tires you can drift with really any setup.
in the movie it is 75amp novatech, 2700 kv keda and 3s 3200mah lipo, as there is not much grip run time is about 10 minutes.
I have 2 compound for the drift tires, soft for higher power and harder for less power.
I'm moving to drift because it is really fun and as you can see from the electronics set up it is even really budget friendly.
Bodyshell is a fiat 500 abarth
