stum
04.21.2009, 02:15 AM
OK she came in today!
First off.. gearing is a 3.9 to calculate with (NOT the same as the crt .5)
Stock spur is 42t, stock pinion is 14t (matches nitro)
Second off this thing is simply AMAZING!
#1 open box
#2 stare
#3 stare some more and smile
#4 take it to my work bench and remove all diffs (running 7k, 10k, 3k) -re-install
#5 install my new Medusa 36x50mm 4800kv (taping the ends to keep dust down inside it)
#6 install mamba and my micro spektrum Rx on the top brace over the center diff
#7 install servo and set
#8 zip tie servo wire to motor mount to keep it from swinging around and getting caught up in the center diff
#9 make some nice pulls
#10 slap a couple stickers on the wing while I wait for hte body to dry
#11 run around the house for a minute, sill smiling big :)
#12 cut up some lexan for rear mud guards (about the only thing left off this bad boy)
I will finish up painting the lid tomorrow.. but here are some pics of the install.. crt .5 owners it's ok if I were you I'd be jealous too!!
The pics!!
