brushlessboy16
brushlessboy16's Avatar
04.21.2009, 11:10 PM
Originally Posted by Finnster View Post
The switches are horrible. The most horrible switches ever. The MM switches are crap too.
I cut them off and put deans mini connectors on wired to a good switch (nitro leftover.) The switches are always a pain to mount as well, so if I have to remove the esc, I leave the switch in place. The nonpolar mini deans can be shunted too if you wanted to bypass the switch.
I epoxied mine to the side of the MMM case in between the power input wires.
should be built into the esc.
