Thread: Spyder diffs
Papa
Papa's Avatar
12.18.2005, 10:46 AM
DO the dace adapters. they capture and clamp the rim over a larger surface area. Stick with plastic 23mm rims, the wabash rims are the wrong offset, go velocity series either dish or for some bling the velo 6 are nice. For 40 series, the cheyenne has the bling. STay away from the bead locks. to heavy. Tire wise unless you race the mashers are a good all around tire . The crime fighters are sweet especially if you race. I do not like 40mm bowtie , no side wall. Traxxas plastic body mounts remain on my rig. The axle bearings for the 6mm Ue cvd's and the racer x knuckles are 6x16x5 you will need 8. The bearings for the servo saver fro UE are included. Transmission 2@6x12x4mm and 2@5x11x4mm. The bearings for your bulhead / Diff, I need to know what you are going with?
