04.22.2009, 02:17 AM
if the internal did draw down quicker than the external, then its voltage would drop, which would then be quickly replenished by the higher voltage of the external battery. they would self balance and work as a system (sort of) just don't leave it plugged in or the back and forth balancing would eventually drain both.
or so I ascertain...
